Wandell Need Some Help!!!!!!!
Old Jun 26, 2007 | 09:02 PM
mooresb86's Avatar
Exclamation Wandell Need Some Help!!!!!!!
Wandell,
I talked to you a couple of times about a few things and ended up changing my mind and i forgot what you told me about the specs for wheels on my truck. I have an 06 f-150 4x4 super crew w/ a leveling kit on it, im wanting to get the micky thompson classic II's put on but cant quite remember all the specs that you said, if you could the specs are listed at the bottom i would like to know if they would fit with a 33x1250x17 tire mounted. Im wanting the tire to stick out of the fender well a couple of inches but don't know for sure if this will work. I also would like to know if this will work if the tires will rubb and if i will have to do some trimming.
Backspacing (in) 5.500 in.
Beadlock Functional No
Beadlock Included No
Center Bore Diameter (in) 4.280 in.
Conical Seat Taper 60 degree
Hub Centric No
Lug Nut Seat Style Conical seat
Offset (mm) +12.00mm
Rim Diameter (in) 17 in.
Rim Width (in) 9.00 in.
Old Jun 26, 2007 | 10:47 PM
wandell's Avatar
That combo will fit fine. Since the MT's have the same backspacing as your OEM 7.5 inch wide wheels, they will stick out 1.5 inches farther. Should be just about perfect.
