Front calipers won't come off
Old Jun 22, 2007 | 06:34 PM
bybyz06's Avatar
The front calipers should just pull right off once the two mounting bolts are removed, correct? Mine are moving about an inch and they feel like they're stuck...does it just take a lot of force to pull these things off, or is there a clip or something else I'm forgetting?
This is on a '05 F-150 4x4 Lariat...
EDIT: I got'em off, just took a little more massaging than I thought.
Old Jun 25, 2007 | 09:07 AM
adamarthur's Avatar
I just did mine on my '06 SCrew this past weekend.... just remember that if you are doing the rear ones to have the emergency brake OFF and also always use a C-Clamp (6" should do) to compress the caliper to allow for easy removal.
FYI... with the E-Brake Off it is especially important to chock the wheels!!!
