Need some rugged looking 16x10 wheels
For a 2000 F150 (5x135mm) I want something that makes the truck look mean and rugged. They're going on 38x14.50 Toyo M/T. They need to be cheap if possible as well. I don't really care about flashy as much as I do tough.
Originally Posted by wandell
I'd go with something with a simulated beadlock, like my Eagle Alloy 102's or the Mickey T Classic Lock.
Haven't seen the Eagle Alloys but the MT only come in 16x8 from what I've seen, which wouldn't work with this tire. I'm looking at the Procomp 1069 or 1079 (same wheel with and without beadlocks). What do you guys think?
I don't know about the Mojave Teflons though. This is going on a brown/tan F150, and I don't think black wheels would necessarily go with the truck. If you can find a pic that shows otherwise though, I'm all for it.
look at the pacer (baja I think) that dondiesel44 has, they look sweet, and I am pretty sure he has them in 16x10.....
whatever wheel you choose of those is gonna look bada$$ with those tires.....
I'm running these on f150 and have gotten a ton of compliments on them. I have the exact same size rim that you would need on my truck right now. They aren't that expensive neither.
Ultra Claws
Ultra Claws
Well I'm about to pull the trigger and pick up some Eagle 187 wheels for cheap.
The wheels are 16x10", offset is -24mm, and backspacing is 4.5"
Again these are going on 38x14.5x16 Toyo Mud Terrains, which are going on a 2WD F150 with the Fabtech 7.5 Crossmember, 3" body lift, and 1.5" leveling kit. How much rubbing do you think I'll see with this tire + wheel combo?
It will be a tight fit since you have a 4x2.
Tight fit is fine for now, as long as it works
. I'm planning on picking up some fiberglass fenders in the near future to help with that anyway.
