Factory Lariat 18" Wheels max pressure rating?
Old Jun 7, 2007 | 10:59 AM
raynik's Avatar
Does anybody know what the max pressure rating is on our stock 18" lariat factory wheels? I know tires have a max pressure rating, but wheels? I have replaced my 'P' rated tires with some 'LT' load range E tires that can hold up to 80 lbs. I don't plan on running them this high for day to day, but when I'm towing I might depending on the load.
Thanks!
Old Jun 7, 2007 | 11:28 AM
kingfish51's Avatar
I believe the wheels are rated to 50lbs. That is high enogh with those LR E tire for anything you want to do.
Old Jun 10, 2007 | 01:35 PM
raynik's Avatar
Does anybody know what would happen if let's say I ran 60 or even 70 psi in these tires (max tire pressure 80)? Would it damage the actual wheel?
Old Jun 10, 2007 | 02:01 PM
kingfish51's Avatar
Don't know if it would damage the wheels, but it would certainly wear out your tires early. On an F150, the axle is rated at about a max of 4,000lbs. Most load range E tires are rated at 3300-3400lbs per tire at 80 psi. 50 psi will give you at least 2000-2200lbs per tire. A rating which is equal to or over what your axle is rated at.
Old Jun 10, 2007 | 02:41 PM
raynik's Avatar
Okay, it would probably give me a little better ride as well. I just purchased a travel trailer and that's why I put the better tires on there. I wany to make sure I cover all my bases before I go pick it up. Thanks for all your help!
Old Jun 10, 2007 | 04:25 PM
kingfish51's Avatar
You really did not have to go with a LR E. It doesn't hurt, but a LR C will max out at about 2400lbs per tire at 50 psi. Again, well above axle rating. I will not put P series on my vehicles, but a LR C or D is not a problem with anything the F150 is rated to carry.
LR E will give you a little less sidewall flex, but you do pay for that a bit with a rougher ride.
