Offset for tire/rim upgrade
Old May 31, 2007 | 09:37 PM
RHWilson's Avatar
I've got a 2001 SuperCrew 4x4 that I got new and it's time to replace or give it a upgrade. So I've decided to give it an upgrade. I've ordered a Troyer Stage 1 and I'm looking to get new tires and rims. It currently has 16" rims.
I'd like to get some 17" rims and then put on the 285/75 R17's. I've seen this set up on a few trucks and I like the look and don't want to have to jack it up.
So my question is, what offset or backspacing is required to keep it from rubbing?
Thanks for your help!
Old Jun 1, 2007 | 12:36 PM
wandell's Avatar
THe OEM backspacing of 4.5 inches will work fine as will 5 inches.
Old Jun 1, 2007 | 09:41 PM
RHWilson's Avatar
Thank you.
Old Jun 1, 2007 | 09:56 PM
SCOTTE`screw's Avatar
go with something bigger,atleast 20" wheels...i got the 17" that came with my truck....not big enough! 20 to 22`s look so much better!
Old Jun 1, 2007 | 10:04 PM
RHWilson's Avatar
So what tires did you put on with the 20's?
Do you have a lift on your truck?
I'll probably crank up the torsion rods to level the front out but I don't want to lift it more than that.
Thanks!
