ABS wire harness
Old May 31, 2007 | 07:07 PM
ckoerner's Avatar
ABS wire harness
My ABS light came on. I went to check the front sensors and the wire harness was laying up against the motor. It popped out of the wheel well mount. The connector housings melted together. My guess is they are shorted together.Where can I find a replacement connector or should I just cut them off and solder them together.
Old May 31, 2007 | 09:06 PM
ckoerner's Avatar
I cut the wires first opposite of the sensor side. I got a 2600 ohm reading. Got the same on the left wheel side. I cut the connector off and soldered the wires. Crawled under the back and measured the back sensor. Nothing. Open. Time to get a sensor. I really thought it was the connector. You couldn't even make out what it is. That's how melted it was.
