Help With Rim Size ASAP...
Old May 30, 2007 | 08:07 PM
NAK150's Avatar
I was down at the shop getting my new 285/75/16 BFG All Terrains put on. The rims I am going with are 16x8 with 5" of backspace. When the guy test fitted a rim, he commented on how litle space there was between the rim and the tie rod end and the brake calliper.
The space was about a finger's width, and he said that a hard bump might cause something to grind or dent the rim. I have the tires mounted and balanced on the rims sitting here. Anyone else go through this? I thought a 16inch rim worked fine on these years? The truck is a 2000 F150 4x4 with the offroad package. Help soon would be appreciated.
Old May 30, 2007 | 08:44 PM
Cuisi's Avatar
I don't quite understand. I would think that if it clears it clears. The only way that would change is if you BENT a rim enough to rub the caliper or tie-rod end and if you did that it would be screwed anyway even if you had more clearance.
Old May 30, 2007 | 09:13 PM
NAK150's Avatar
Yea thats what I figured. I talked to a mechanic buddy who said if there is clearnace when they are tightened down, they I sould be fine. He said they wont go anywhere and any clearance should work. Anyone else with 16" rims on this model?
Old May 30, 2007 | 09:56 PM
dondiesel444's Avatar
I have 16" rims, many of us do. as long as everything clears when the rim is installed and spins freely, nothing is gonna change driving down the road. a fingers width is plenty of room, get thos tires and wheels installed and don't worry about it!!
you say you have 5" bs, the 16x8 steel wheels I just removed had 5" and they were fine. my new ones have 4.25" and stick out way more than the old ones.
Old May 30, 2007 | 10:00 PM
NAK150's Avatar
Wow is that a relief . I'm going to go ahead and get them put on. Too bad JEGS had to send me the wrong size lug nuts, now I have to wait again to see them mounted .
Old May 30, 2007 | 10:18 PM
wandell's Avatar
I agree with dondiesel444 and Cuisi.
Old May 31, 2007 | 06:00 AM
yea I guess you know by now you need 14mm x 2.0 lugnuts, all the stores around here had 14 mm x 1.5
