Wide Stance Help
Old May 30, 2007 | 01:10 PM
Foxacrombie's Avatar
Wide Stance Help
Hey Yall,
I've got a couple questions concerning new tires. I have a 2wd scew with 2.5 AS leveling, and 3" PA Body lift. Currently I'm running 275 65 18's (32 inch tire). I'm going to get 17x9 MM Chrome 951s, and I'm thinking 295 70 17s, or the Irok 33x13.5 17s. I'm going for a wider stance, and if you can tell from the picture below, I think 35s with a close to stock setup, would sufficate the wheel well too much. If I went with a 33, it'd leave a nice gap and I could blow it out to a wide stance like i'm wanting. I could get the MM's in 4.53" BS and -12 Offset.
Would this be a good setup for a wide stance?
Anybody have any 2wd BL w/ 33" tires?
Old May 30, 2007 | 03:19 PM
chumFX4's Avatar
A 9" rim with 4.5" to 5" of backspacing will give you the wide stance you are looking for. Mine are 5" of BS and I have 13.5" wide tires. If you go with the BS around 4.5" like the rims you described, a 13.5" wide tire might stick out a little too much, IMO. But the look you want is up to you. Heres a pic, it might help you get a visual idea, sorry the truck isn't black......
Old May 30, 2007 | 10:14 PM
wandell's Avatar
I agree.
