Should I be in the CLEAR? Wandell
I'm running 22" Rockstars w/ 6.75 backspacing, offset +12mm, 305/45/22 tires with no rubbing at all, so if i installed a "6 lift from ProComp or Fabtech and went with 325/50/22 tire =35" i should be in the CLEAR? Also a 325mm = 12.79"wide tire should fit on a 9.5" rim? Thanks
