Will a 315-70-17 fit?
Old May 18, 2007 | 09:20 PM
vipz's Avatar
I have a 2005 4x4 crewcab F-150. I currently have a 2.5" leveling kit and was wondering if some 315-70-17 tires on a set of 17x8.5" rims with 5.5 or 5.75 inches of backspacing would fit without rubbing. I know there are a few people running this tires size with some 17x8's but I was hoping to go with some 8.5's. Thanks for any info
Old May 18, 2007 | 09:57 PM
wandell's Avatar
You will have some rubbing.
Old May 18, 2007 | 10:02 PM
vipz's Avatar
Thanks for the reply. Do you think I will have rubbing if I go with
some 17x8's with the 5.5" backspacing? Thanks
Old May 18, 2007 | 10:08 PM
wandell's Avatar
Probably a little, but I doubt it will be something that some minor trimming won't cure.
Old May 18, 2007 | 10:20 PM
I just put my 315's back on, no rubbing on a 17x8 with 5 1/2" BS even doing some minor offroading. Had them on 17x9 with 5" BS prior and had minor rubbing on the lower wheelwells. Also the new wheels keep's them inside the wheelwells and keep's these rock throwing BFG's from tearing up the sides of my truck!
Old May 18, 2007 | 11:08 PM
vipz's Avatar
With your setup are the tires pretty flush with the fenders or do they stick in behind the fenders like the stock look? I have the edge....do they hurt the power much? Thanks
Old May 19, 2007 | 04:01 PM
04 Supercrew's Avatar
How about a 315/70/17 on a 17x9 with 5.5 BS?
Old May 20, 2007 | 10:01 AM
wandell's Avatar
I'm not sure. But that would be a little better than PawPaw's original setup and he said he only had minor rubbing.
