Just ordered!! need some help
Old May 16, 2007 | 08:36 AM
badz_83's Avatar
Hey all, this is my 1st post and just wanna say looove the forum! I've learnt alot of information from the past two days reading over it, but I needed to ask a question..
I've just ordered a 6" pro comp lift with Nitto 35" X 12.5" X 20" tires and also some KMC 127 20" X 8.5" rims. The problem I think I will have is that these rims have a VERY posotive offset. Here are there specs:
Back Spacing = 6.24 in.
Offset = 38 mm.
Now I purchased some Bushwacker flares but know I won't be using them since the tires will not be sticking out... Can someone help me out?
I need to know if my tires will fit perfect without rubbing on these rims and whether or not I should cancel the fender flares or change the rims! I do have som XDs in mind which look almost similart to the KMCs...
KMC 127 Dime rims:
XD 795 Hoss rims:
Old May 16, 2007 | 12:19 PM
wandell's Avatar
Those wheels are only gonna stick out about 1/4 inch more than the OEM 17 and 18 inch wheels. They should fit fine, but it's up to you as to whether or not you like the look.
