Will they fit? 285/70/17
I have a 2004 STX flareside and am looking at getting 285/70/17s on the truck. I need to do ASAP as my front passenger tire is showing radials from inside wear. Just noticed today.
Will these tires fit without leveling kit? Without rubbing?
Thanks in advance
Thanks in advance
Check this thread...
https://www.f150online.com/forums/sh...d.php?t=283627
I just put BFG 285/70/17's on my stock '06 crew cab. They fit fine. Don't see any reason why they wouldn't fit on your STX. But you can certainly have them do a test fit at a tire shop before you buy 'em.
good luck!
good luck!
Originally Posted by ljhookem
mt b8, are those stock door handles or aftermarket? If they are aftermarket....what kind?
I've got an STX 4x4 with the 2" AS leveling kit. I got some 285/70-17s and I have some room to spare, absolutely no rubbing ever. With a 2wd truck, I think these would be about the biggest you can go. I could be wrong though. Do a little searching and I'm sure you could find a definite answer.
