33x13.50 Tire Help!!!
I was wondering if I could fit a 33x13.50 on a 06 leveled fx4. I was thinking about mounting them on mickey thompson classic locks. I wheels are 17x9 with 5.5 backspacing. I really dont want them to rub. I have seen one member with this setup and but cant seem to get a hold of him.
I just put on 33x12.5 on 17x9 with 4.75 backspace and have no rubbing on my 06 4x4 Screw with 2.5" leveling kit. My tires really stick out there but your 5.5 backspace should be a good choice. You will probably be sticking out just as far as I am because you have the 13.5 instead of the 12.5
It you rubbed at all you could fix it very easily. I had to trim about 1" off the inner fender flare and added a screw. Pics are in my gallery, nothing you can not do and no one would see or know unless you point it out.
With 5.5" BS I don't think you will rub at all...
my iroks they ride good balanced ok my normal tire shop wouldnt balance them for me so i end up finding a new shop to do my business also My brush grill guard is the Warn Transformer
Before i went with the procomp stage 2 kit i was runnin the 33x13.50x18 iroks with zero rubbing on revtek 2" front lvling kit
