changing wheels, affect speedo?
i am changing my oem 18" lariat wheels w/stock tires with oem 20" wheels w/stock tires and was wondering if it will affect my speedo?
Originally Posted by wandell
It's tire height that causes the speedometer to be off, bit wheel size. If the two tires are the same height, your speedo will not be off.
Originally Posted by kingfish51
You don't need to compare them that way. If you have the tire sizes, you can plug the values in here. It will tell you the difference and how much if any the speedometer will be off.
I was thinking about swapping my oem 18's for some oem 20's but wasn't sure if the '05 models had tire pressure sensors. If so would I have to get new sensors if I swapped my wheels? Any info would be appreciated. Thanks.
If you have tire pressure sensors, just swap them onto the new wheels.
Tire pressure sensors started on the F150 in 07. Yes you would have to break down one side of the wheel to get the sensors out if you had them.
