7.5 and tires
Alright another question! i am wanting to go with the Helo Max 6 rim http://www.4wheelparts.com/PDT71847.aspx
I will be getting 17 inch rims with 315 70 17 inch tires. now what backspacing should i get? I want the tires to stick out a little bit with the 7.5 but not too much. thanks!
That tire will fit fine....you will have pleanty of room, I hve 6" on a 2WD and run 315's easily.
As far as the wheels sticking out, I would not get a big offset wheel, cause the fronts are going to be about an 1"-1.5" wider on each side anyhow. You might want wheel spacers for the rear if you want them to look the same.
