Level Lift Question
Old Mar 20, 2007 | 02:45 PM
cnichols74's Avatar
Level Lift Question
I was trying to purchase a ProComp 2.5" level lift kit and the guy at the shop told me that it wouldn't accomodate 35" Terra Grapplers. Is this true? Any suggestions on where to buy a kit to accomodate these tires and have it shipped to me in about 3 days?
Old Mar 20, 2007 | 07:39 PM
LESSTANFORDFORD's Avatar
There will be a problem....
It should rub with 35's. I have a level kit on my personal F150 and the 33" Terra Grapplers are about an inch shy of rubbing. If you plan on 35's you should consider a small body lift in conjunction
Old Mar 20, 2007 | 07:54 PM
BalogUK's Avatar
as said above- 35's will fit but they rub...
im running 35x12.5R18's on stock wheels with a 2.5" autospring leveling kit- the rubbing is minor-
Old Mar 20, 2007 | 08:02 PM
wandell's Avatar
Right. It depends on the wheel you use. As a general rule with a leveling kit on a new 4x4 you can fit 35x12.50's using the OEM wheels or 33's with aftermarket wheels.
Old Mar 20, 2007 | 08:45 PM
cnichols74's Avatar
I have 20" aftermarket wheels. Will the 33's look fairly tall with the aftermarket wheels? I have T Grappler 305/50/20 tires (They're about 32" tall). Would a 305/55/20 BFG AT look pretty good or would you stick with a new set of 33" T Grapplers?
Old Mar 21, 2007 | 12:37 PM
wandell's Avatar
A 33 on a 20 inch wheel is gonna look pretty short. It would look a little better than the 32's you have now though.
