Help me with my selection...Please
Old Mar 18, 2007 | 05:49 PM
gator_79's Avatar
Hi all, I'm a new member and I've been reading some topics on here. I drive a 2003 F-150XLT 4x4. It has a sido Flowmaster Exhaust, K&N cold air intake, and superchips tuner. The factory tires are wearing out and I'm ready to upgrade. I'm going to get the Helo Maxx 6 rims, black w/ machined lip 17x9. My questions are: Should I order the rims in 4 1/2 or 5 3/8 backspace? I'm not sure what that means but thats the 2 options. Also will 305/70/17 or 295/70/17 tires fit, I don't mind cranking the torsion bars up an inch or so. I was thinking of an add a leaf in the back and after market torsion keys in the front to get couple extra inches of lift. What these be necessary to fit the tires I want. I have also read both positive and negative comments on the torsion keys, what do you think? I do a lot of hunting and fishing so my truck does see some off road use. Thanks for the help!
Old Mar 18, 2007 | 08:06 PM
wandell's Avatar
I'd go with the 17x9's with 4.5 inches of backspacing which is what your OEM wheels have. Personally, I'd go with a 305/65-17 (33x12.50) tire but you should be able to fit the 305/70-17's (34x12.50) if you choose. Also, I'd just crank up the torsion bars with the OEM adjustment keys. The aftermarket keys allow you to put way too much preload on your torsion bars.
