I just bought a set of 22 inch pinnacle blaze rims and tires are 305 40 22 will that fit on a 2006 f150 screw with out a lift kit with no problem?alsocan i use my factory lugs with them
Quote:
Not sure on the lug issue but you are fine without a liftOriginally Posted by 1stFord4Boss
yah its going to depend on if the new wheels are lug centric, or hub centric. Meaning if the wheel is centered by a tight fit over the hub, or if you use the conical lugs to center the wheel on the truck.
Stock wheels are hub centric, and alot of the aftermarket wheels are lug centric
-Patrick
-Patrick
i have the same wheel and tire combo on my truck but my rims came with the lugs for them i just had to buy the locks which were like 20 bucks. they fit well being fluch with the fenderwell but i just dont like the gap between the top of the rear tires and the body of the truck. want to lower it with jdm but scared that it will take away from my towing becaused i have hit a few bumps that really had the truck bouncing and scared that it would bottom out if lowered.
Quote:
Got pics?Originally Posted by dirtyo2000
Quote:
bumpOriginally Posted by 4RDFMLY
Got pics?
