well 37's fit
no they wont fit
you will have some rubbing with 35s
also your truck has a torsion bar front suspension, if you want a lil more lift on the front you just crank them a little bit
if you installed a 3" body lift on top of the 6" susp you could fit 37s or even 38s
i have seen 37" with just a 6" fabtech but they had to crank the torsions all the way and take off his fender flares and do some major trimming, it can be done, but it will fit alot easer with a 6" and a 3 inch body it will look better also. good luck
