Tire size question- 34"
Old Feb 19, 2007 | 11:47 PM
05screw84's Avatar
Hey guys im new to the forum and trying to get an answer for yet another tire fit question. My truck is a 2005 F150 4x4 all stock. My question is will a set of moto metal 17x9 951's fit with 305/70/17 nitto terra grapplers (34x12.5) I havent seen anyone with this setup yet. Which backspace is correct for this setup? Also, will I need a leveling kit? Thanks for the input, you guys are awesome!
Old Feb 19, 2007 | 11:53 PM
jackjackobo's Avatar
I think it will fit. Wandell may give you the best answer.
Old Feb 20, 2007 | 12:56 AM
05screw84's Avatar
Okay, after another hour of searching I now think my best bet at fitting this setup is with the 17x9 with 6" backspacing. I see people have run tires close to this, but Ill wait for wandell's answer for this one. Leveling kit required?
Old Feb 20, 2007 | 08:28 AM
06STX4x4's Avatar
I would say go with a leveling kit period, but the 6" BS will definitely work better. The 4.5" would not work at all even with the leveler.
Old Feb 20, 2007 | 12:26 PM
wandell's Avatar
They will be extremely tight. They may work with 6 inches of backspacing.
Old Feb 20, 2007 | 02:05 PM
05screw84's Avatar
What is your best guess where I may have problems? Inside, outside, bumper...or is this going to be close everywhere? I don't go off road, just snow and jobsites so I don't think I would be maxing out the suspension travel. Would the height of the leveling kit make a difference, or a small spacer behind the wheel? Im not dead set on this setup, but I already have 285/70/17 and would like something a little bigger without lifting the truck. If not then im stuck with what most other people run, 33x12.5
Old Feb 20, 2007 | 06:47 PM
The 305 tires are about 33.7 inches tall, on a 17x9 wheel with a 5 to 6" BS you ought to be OK if the truck is leveled. I had 315's on 17x9 wheels w/5" BS and the only place they rubbed was the lower wheelwells and the 315's were 34.5 inches. I put on some 285's and have lot's of room.
