Thud when braking
Thud when braking
You can hear a thud in the front and feel it lightly through the floor board. It happens only when you first go to apply the brakes and it is just a single thud. Now if I went and pressed the brakes very slowly and softly it won't do it. Also if I press the brakes and let go and immediately press them again it will not do it. So it does it at any speed and when I go to normally press the brake and makes the thud just as soon as I start to apply the brakes. It does not seem to be braking awkwardly at all. What do you all think it is.
Radius arm bushing wore out will cause that thump also. Its Y shaped beam on the front alxe to the frame mount. When they go bad it allows the front alxe to shift back and forth especially when you hit the brakes....................
There is no loose cargo but good thought. I gave you all info of what it was doing but didn't tell you what I have. It's a 97 4x4 5spd 4.6L. My truck doesn't have radius arms though according to haynes. My brothers 93 4x4 does and I know what they look like. Could it be the lower control arm? Also I haven't had time to look around on it. Will do that tomorrow morning. Thinks for the replies.
check out your brakes first. caliper bolts etc... i had the same thing happen on my dakota and it ended up being my upper control arm bushings were gone.
