spare tire....do i need it?
Old Feb 17, 2007 | 04:50 AM
matthewfedex's Avatar
just curious if most of you guys that have upgraded tires to a larger size are still carrying your spare? i'm running 35's now and i've heard driving with my spare could cause some damage to the truck. if so what's the point of still carrying the extra weight? what do you guys think?
Old Feb 17, 2007 | 07:46 AM
Up to you. What are you going to do if you get a flat? I suppose it depends where it happens. I think I'd rather drive on a mismatched spare carefully and slowly than pay for a tow or leave my truck on the side of the road sitting up on a jack waiting for someone to come bail my *** out. Friends aren't that friendly any more at 3am.
I may be old school, but i won't drive anywhere without a spare - even if it's a silly little doughnut.
Old Feb 17, 2007 | 08:32 AM
Tripyn69's Avatar
Matthew, I felt the same way-wondering what to do about my spare and worrying about getting a flat; ended up buying a full size spare just for piece of mind. I managed to squeeze a 35X13X18 up under there, it was tight but it fit and barely noticeable too! The way I look at it, I will have to buy one less tire in 2 years and I can just rotate an old one to the spare.
You can also look out on E-Bay-I was able to locate a used tire (same brand and size) for a third of the cost. Of course, this was after buying a brand new one!
Old Feb 17, 2007 | 09:19 AM
hivoltagefx4's Avatar
I plan on buying some 33's. So are you guys telling me that I could indeed fit a 33 under there? I am running 20" wheels and I assume my spare is an 18" will a 33 on a 20" wheel fit under there????
Old Feb 17, 2007 | 09:34 AM
wandell's Avatar
I still have my OEM 255/70-16 (30 inch) spare. I told my tire guy last week to call me if he found a used 315/75-16 that would still hold air.
Old Feb 17, 2007 | 09:51 AM
Tripyn69's Avatar
Hivoltage-I measured it before I put it under there and it was right at 35 inches tall. You could try one of the rims off your truck before hand just to make sure, that is what I did before investing in another tire.
Old Feb 17, 2007 | 09:57 AM
dharris1969's Avatar
If, you go off roading and the way out requires four wheel drive, you run the risk of damaging your t-case. Spend the money and buy a matching tire. You can install the tire in your truck bed and lock it with a cable.
Old Feb 17, 2007 | 10:59 AM
attitude's Avatar
Yes I would leave a spare under there!!! Even if it is a smaller tire. I always hang on to old tires we take off just for this reason. (And for buddies with the same situation) I know a 315/75/16 will fit under the superduty, Will it fit under a supercrew(2001)? You don't need to worry about the same rim et.c just the same size tire diam. Example: I wouldn't buy another 20" wheel with a 35" tire, just use a factory wheel and find a used 35" tire, Like wandel said. All it's gotta do is hold air and get you to the nearest town.
Shane
Old Feb 17, 2007 | 01:15 PM
wandell's Avatar
Yeah, several members at FTW have fit 35 inch tires underneath 97-03 F-150's in the stock spare location.
Old Feb 17, 2007 | 04:37 PM
I carry the same diameter spare in the bed of my truck with extra lugs and a floor jack also a good breaker bar helps too!
