265/75/16 Tire Recommendations
I am getting ready to install some type of lift (preferabbly 2" spacers of some sort) in the front of my 99 2wd Scab. I was told that 265/75/16s would clear fine with this lift and would be fine in the rear clearance wise (though I really want to raise the rear an inch or so). I'm not looking for any real aggresive tread pattern or anything as the truck will never see off road. So I'm looking for the best bang-for-the-buck tire I can find that still has an aggresive-type look. Something like the BFG All Terrains or something like that. So, got any suggestions for me!? Thanks in advance!!
Originally Posted by wandell
You can fit that size without a lift, but I agree that they will look better with a lift. I'd suggest the BFG AT KO's, Nitto Terra Grapplers or Toyo AT's.
You could fit 285/75-16's (33x11.50) if you use the OEM or 16x8 (with 4.5 inches of backspacing) inch wheels.
This isn't my truck, but these are the wheels that I have.
Originally Posted by MmmBuckles
i have 265/75/16s on mine right now. and they fit just fine. you can fit up to 285s on a stock with no spacer, but there will be a little rubbing.
