Help with rubbing issues
Old Feb 4, 2007 | 10:43 AM
Richwm's Avatar
On a 2005 Lariat Screw 4X2 with a readylift leveling kit.
Ok here is what I did I put Pro Comp Xtreme Alloy 1069 18x9,6x135Bolt Pattern,Offset-6,4.75in BS with 325/65/18 Pirelli Scorpion ATR's and have some real rubbing issues. I can't even park my truck with out rubbing and I already cut all the plastic I can and the metal in the fender well is next but I don't want to cut metal if its still going to rub after.
Old Feb 4, 2007 | 02:17 PM
wandell's Avatar
A 325/65-18 (35x13.00) tire is way to big for a 4x2 (or a 4x4 for that matter) with only a leveling kit. You basically have two options. Remove the leveling kit and install a 6 inch Pro Comp or Fabtech lift kit. Or you can go to a smaller tire like a 285/70-17 (33x11.50) or maybe a 305/65-17 (33x12.50).
Also, welcome to the site.
Old Feb 5, 2007 | 10:32 PM
Richwm's Avatar
Thank you, not what I wanted to hear but here is a picture of what it looks like.
Old Feb 5, 2007 | 11:04 PM
Relamancer's Avatar
That sucks man... that truck looks good too... Good luck with your decision...
Old Feb 5, 2007 | 11:25 PM
Richwm's Avatar
Old Feb 6, 2007 | 07:57 AM
wandell's Avatar
Yep, your truck looks good. It would look great with a 6 inch lift!
Old Feb 6, 2007 | 12:17 PM
pkent03F-150's Avatar
get a 2.5 inch leveling kit and a 3 inch body i dont see how you are driving it with that setup and how you can steer it
Old Feb 6, 2007 | 01:32 PM
Richwm's Avatar
I have a 3" readylift leveling kit and it only rubs a little now when I back up and turn after I modified the wheel well a little.
See this link http://www.offroadwarehouse.com/Stor...15410!Cat!1252
Readylift Leveling Suspension for 2004-2006 Ford F-150 2 & 4wd #REA66-2050
Readylift is the fastest, safest, lest expensive way to level a truck and add tires up to 35" in diameter. While other lift kits costs much more and take hours to install, Readylift can be installed in as little as 30 minutes and costs less than the price of a single wheel.
Readylift's Shock Extensions are made from plate steel over 1/4" thick and mount on top of the shock assembly, eliminating the hassle and danger of compressing the springs unlike urethane spring inserts. The Shock Extensions never wear out and come with Readylift's Lifetime Warranty. Keep stock suspension "feel" while raising the front up to 3".
Old Feb 6, 2007 | 02:30 PM
Richwm's Avatar
here are some more pictures
Old Feb 6, 2007 | 04:19 PM
wandell's Avatar
Wow, $229 for a leveling kit?
Old Feb 6, 2007 | 04:35 PM
djh1121's Avatar
Your truck looks great, just add a 6" lift...
Old Feb 6, 2007 | 05:41 PM
Richwm's Avatar
So did I pay too much?
Old Feb 6, 2007 | 06:35 PM
Mange's Avatar
Haven't seen a 3", but the 2.5's go for around 75-125 bucks.
Old Mar 8, 2007 | 10:24 PM
Richwm's Avatar
Ok so I did it today I had a 6" Fabtech lift kit installed.
Thanks for all of your advice[IMG][/IMG]
Old Mar 8, 2007 | 10:30 PM
wxscpo's Avatar
Would love to see some pictures of your new setup. I will be adding a 6" Fabtech to mine real soon and a set of the same size tires. Did you end up keeping your leveling kit on as well or did you remove that when you added the lift kit? Thanks
