How tight will this be?
Old Jan 16, 2007 | 08:01 PM
Damon30's Avatar
I plan on putting a 2.5 AS leveling kit with Black Moto Metal 951 17x9 12mm offset and bs of 4.53 with 315/70/17 bfg's on 05 4x4. Do you think this will fit?
Old Jan 16, 2007 | 08:18 PM
wandell's Avatar
No. You will need to stick with 33's or add at least a 3 inch body lift to fit 35's using those wheels.
Old Jan 16, 2007 | 08:45 PM
Damon30's Avatar
Thanks Wandell...Could I fit those tires with rims that had a different backspacing?
Old Jan 16, 2007 | 10:01 PM
Dog'em's Avatar
If you are going with a 17x9 rim you will need at least 5.5" of backspace. I'm running 20x9 rim with 6" backspace and 35" tires with no issues.
Old Jan 16, 2007 | 10:13 PM
Damon30's Avatar
Thanks Dog'em, now I gotta find a rim with the right backspacing
Old Jan 17, 2007 | 07:59 AM
wandell's Avatar
You would need something close to the OEM wheel specs (7.5 inches wide with 5.5 inches of backspacing). You might could fit them with an 8 inch wide wheel with 5.5 inches of backspacing.
Old Jan 17, 2007 | 09:39 AM
Damon30's Avatar
Wandell,
Would those tire fit on a 7.5 in stock rim?
Old Jan 17, 2007 | 04:02 PM
wandell's Avatar
Yes, several members here and FTW are running that combo.
Old Jan 17, 2007 | 07:44 PM
Damon30's Avatar
Thanks Wandell! Great input as always
