brakes problem
Old Jan 1, 2007 | 10:06 PM
MmmBuckles's Avatar
brakes problem
ok. so i just replaced my pads like a month ago because they were totally gone and i almost died because of it. well lately i have been noticing that they are having some problems. whenever im at a stop my breakin seem to release. but only when the AC is on. whenever the engine revs a bit for the ac compressor, the brakes slip. and as soon as the compressor stop, they clamp back down. i cant seem to found out why this is happening. any ideas?
Old Jan 1, 2007 | 10:35 PM
built54's Avatar
yeah, mine does that if i dont have much pressure on the pedal, nothing to worry about
Old Jan 3, 2007 | 05:26 AM
Duffman0286's Avatar
might be a good idea to have ur booster check for leaks my truck dont have that problem
Old Jan 3, 2007 | 05:58 AM
jbrew's Avatar
My 98 hasn't done that either ...Idunno.
Do both you guys have a trailer brake setup - Kelsey Hays maybe..??
Those will do that..
Old Jan 3, 2007 | 09:04 AM
Joe315's Avatar
I had the same problem after I changed my brake pads, long story short one of the rotors was slightly warped. The pad would grap the warped part and if I lightly held on the brake and the engine rpms increased the brake pad would slip off the warped part of the rotor. I changed my rotors and I havent had the problem since. Do you have some vibration or bouncing when you apply the brakes?
Old Jan 3, 2007 | 11:42 AM
keith97xlt's Avatar
check your booster and master cylinder. that doesnt sound right.
Old Jan 3, 2007 | 03:31 PM
jbrew's Avatar
do u have an f150 ?
If you scroll up to "user CP" in the black bar cross the top"click" - then go too "edit profile" - click click then scroll down a bit, you can fill in the blanks and then all the way down and hit "save" - Your truck will show up on the right when you post - makes it easier to comment
Thanx
Old Jan 3, 2007 | 03:33 PM
keith97xlt's Avatar
when i said "that doesnt sound right" i meant the brakes slipping isnt right,not check booster and cylinder.
Old Jan 3, 2007 | 03:54 PM
also might be time for new brake fluid, lines etc or atleast bleed the lines.
Old Jan 3, 2007 | 03:56 PM
jbrew's Avatar
What sucks, if upgrade your pads , it's harder on the rotors - The stock rotors will warp if you look cross eyed at them. Due check the booster - good idea..Your 99 has 4 - my 98 has 2 , 98's had drums in the back.
Before my brother traded his 99 in , his acted goofy after he put a KH trailer brake kit on..
If you upgrade a little on the rotors - "Brembo's" Good and Cheap and get "Raybestes Carquest 2 year Blue pads" - She'll stop sweeter than mine does right now..Stay away from Ceramics , too hard of a pad, unless u have slotted rotors..Chaching..$350 for all.
Whats happining on the one rotor is the Twin Cam Caliper isn't working correctly, each Cam is applying different pressure. Its easier to replace the Calipers 4 - $200 tho if you go that route . You could just replace the one as well. Changing the brake fluid and adding fresh will give you more stopping power yet..
Old Jan 3, 2007 | 03:57 PM
jbrew's Avatar
Hang-on Patrick - I got it
I was typing
lol, sup bro
Old Jan 3, 2007 | 03:59 PM
jbrew's Avatar
That's cool , thought u might wanna put your truck up there..
Old Jan 3, 2007 | 04:09 PM
I was typing
lol, sup bro
with 3 posts, you are going to catch up to me in no time.
and happy new years to you.
Old Jan 3, 2007 | 04:16 PM
jbrew's Avatar
Happy New Years
I thought you just hit 2000 two weeks ago???
2300
Old Jan 3, 2007 | 04:27 PM
Happy New Years
2300
I think i was 2000 about 3 weeks ago, was 2100 very shortly after, and just hit 2300 yesterday.
