PSI 305/55/20 Nitto Terra Grappler
Old Nov 30, 2006 | 10:34 AM
keithf150tx's Avatar
I am runnning 305/55/20 Nitto Terra Grapplers on stock 20's , what psi should I run in them?
Old Nov 30, 2006 | 10:42 AM
kingfish51's Avatar
Per their website, those are an LT load range E tire with a max of 65psi. I would try somewhere in the 45-50 range. As the max is 65, I would try at the low of that range first and see how it wears.
Old Nov 30, 2006 | 01:12 PM
Nightrider's Avatar
I am looking at the same size tire for my stockers. Do you have any pics? Also is that about a 34" sized tire or ? Do you have a lift or anything and if not are you getting any rubbing? Thanks.
Old Nov 30, 2006 | 03:58 PM
wandell's Avatar
I've found 40 psi to work fine in most truck tires. Also, a 305/55-20 is basically a 33x12.50-20 tire.
