PSI with 325/65/18
Originally Posted by SVTErick
What PSI is everyone running on their 325/60 and 325/65 tires on stock FX4 wheels. I am at 35 psi each tire. Whats the best for even wear?
That is an LT load range D tire according to their site. I would try around 44. Because you are running it on a wheel that is really too narrow for it, (they don't list the width range, but show details on a 9.5" wide rim), you may have to lower the pressure a little bit to get decent tire wear, but not too much. Go too low and you take a chance with overheating the tire and having a blowout or tread separation. I wouldn't go lower than 40.
They really don't give you much info on that site, like the rim width range, weight carrying ability, etc.
Originally Posted by smitty'slariat
I ordered the 305/65/18 BFG all terrian and they are load range E what psi should I run on factory rims cause I get them on next week.
Originally Posted by BalogUK
what is that- a 32" tire? id say run from 36 psi to 40
again, i work at diso**** tire, we put these on all day, everyday.
if its a 33 or less.. u dont need more then 35 unless its on a heavy duty.. (250 or up)
the 150 only needs 35.. if u want better gas milage, (minimal, but better then nuthin) then run it higher.. if u mudding, u want ur tire pressure low, so that ur tire is wider, instead or narrow, then jsut fill up afterwards. but dont run on the road at high speeds at a low pressure.. u will have a blow out.
u want a bubble in ur tire .. just put it that way.
