brake help??????????????
Old Nov 23, 2006 | 11:01 AM
ford35192's Avatar
Question brake help??????????????
Im replacing the front rotors on my 1992 f150 2wd what all parts do i need to replace the odds and ends (seals, bearings etc.) of the assembly??
Thanks,
Old Nov 23, 2006 | 04:56 PM
BLUE20004X4's Avatar
I would definetely repack the bearings with grease (a give in) after a thorough inspection. Ask you're parts guy, or just see yourself what's needed because usually all I ever had to do was repack the bearings, the seals, races, etc were always good. The only time I replaced everything was the disc swap on my 64 Galaxie because everything was crap and cheap enough to replace, just start brand new.
Old Nov 23, 2006 | 09:23 PM
Steve83's Avatar
If the rotors are gone, you should be able to buy them "loaded" with packed bearings & seals preinstalled. If your rotors are OK, you won't need to mess with the bearings or seals. Just pull the calipers & swap the pads.
You can get a few pointers by clicking my signature link & looking in the Brakes & Hubs album, but it's geared more towards 4WD trucks. The calipers mount the same, though.
