6" or 4" with biggest tires
whats the biggest tires i can get on a 4" rancho lift? what about the popular 6" by any company? will i be able to fit 37s"? thanks guys for all ur help. i really like the nitto mud grappler so that would be the tire of choice unless anyone has a better one. thanks fellas
You can fit 35 with the Rancho. You will be able to fit 37x12.50's with a 6 inch lift if you use the right wheel. I believe a few members have done this. You will probably need a 9 inch wide wheel with 5.5 inches of backspacing or more.
should we be able to fit a 36/37 under a 4in if its got a probly backspaced rim we can do 35s with a 3in body why not 37 add a inch in hight and you gain a extra one with the lift may have to crank torisons a bit for those us that can
