Torque Specs on Stock 17"
Just bought new tires for my '98 STX. Using 265-70-R17 Pirelli Scorpion ATR. Do not have the manual for the truck. What is the right torque for the lug nuts??
Also, does anyone have the jack stand page from the owners manual that they could e-fax to me? Can not figure out with limited jack height where the correct placement should be.
thanks
thanks
stands can be put anywhere on the frame. The suplied bottle jack is supposed to lift from rear axle, or there is a special lift point coming down off the frame, right where it starts coming down under the cab (up front near front door seam)
And i usually torque mine by hand with the lug wrench, b.c if i can get them on i can get the off myself on the side of the road if needed. But i think the spec is 70-75ftlbs
-Patrick
-Patrick
