Front end shakes after hitting breaks
Old Oct 15, 2006 | 11:41 AM
alsayre's Avatar
Hello all i have a 97 f150 and i had the front end worked on had all the ball joints replaced tie rod ends replaced. and now when i hit the breaks the front end shakes i thought it could be the rotors being out of wacked but there not. the mech can't explain what is wrong could it be the shocks but it only shakes when i hit the breaks.. so confused
Old Oct 15, 2006 | 04:19 PM
ian51279's Avatar
If it only shakes when you hit the brakes, then its the brakes. How long have the current brakes been on there? I'd bet that they are "warped". It may not be much according to your mechanic, but even a little bit can be felt.
Old Oct 17, 2006 | 12:56 PM
tiny1's Avatar
I have to agree that the rotors are the culprit. I just did the front brakes on my truck and once and awhile with the old rotors, I could feel that they were warped "very slightly" by having a shake in the steering wheel. So for around 50 bucks each, I replaced the rotors and have very nice smooth braking
Old Oct 17, 2006 | 02:27 PM
Jordan not Mike's Avatar
If they've been measured and don't have excessive runout (warping), then it's an uneven transfer layer:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
http://www.zeckhausen.com/avoiding_brake_judder.htm
Happens a lot.
Try removing the existing transfer layer, then bed your pads.
It's free and relatively easy to do.
