i need help finding tires
Old Oct 11, 2006 | 11:01 PM
Tyrod88's Avatar
i need new tires on my 05 screw. i don't have the money for new rims and i can't afford a lift. i want to put more agressive tires on and maybe a little bit wider but i can't seem to find a tire that will fit my 18" stock wheel and stock ride hight. i don't know if i'm not looking hard enough or what but i could really use some help finding some mud terrains or some agressive allterains to fit my truck thanks for the help
Old Oct 11, 2006 | 11:12 PM
wandell's Avatar
BFG makes the AT KO and MT KM in 285/65-18 (33x11.50). They will fit a 4x4 easily and will fit a 4x2 with a leveling kit using the OEM wheels. If you have a 4x4 you can run a 35x12.50-18 with a leveling kit and OEM wheels. THe BFG MT KM, Toyo MT and Nitto Mud Grappler are available in this size.
Old Oct 12, 2006 | 09:35 PM
skirk55's Avatar
I just replaced my tires and put on a leveling kit. My F350 had 33" tires on it and they were junk. After asking 100 questions I went and purchased 35x12.50x18 Cooper STT and used my stock rims. I also put on a Ready Lift leveling kit. This was easy to do with big results! I can't tell you how much better the truck looks and drives. The ride is a big improvement over stock. I also put on Pro Comp ES3000 shocks. Wandell will tell it to you straight he was a big help with my set up!
