new brake ideas...
Old Sep 9, 2006 | 02:55 PM
socalbob's Avatar
new brake ideas...
Noticed several posts re front rotors warping and associated pedal shimmy. I have a 04 FX4 and had to have the rotors turned at 2,500 miles and replaced at 10,000 miles... and I am still unhappy.
Someone posted that the dealer replaced their brakes with the new 06 version... my question is should I opt for the new Ford brakes or go aftermarket with Brembo / Stillen? I really don't want to dump $3K into new brake system but I am leary of putting OEM parts back on truck unless I have some confidence that the 06 version is an improvement.
Any ideas or comments would be helpful... I need to replace brakes SOON... getting down to the danger zone on my pads. https://www.f150online.com/forums/im...s/confused.gif
Old Sep 9, 2006 | 04:24 PM
Jordan not Mike's Avatar
IMHO putting the same old parts on will give you the same results.
Aftermarket replacement parts may be helpful and far less expensive. You may want to start there.
I run Brembo plain rotors ($70 each) with Hawk HPS pads ($70/set).
Search these forums, lots of guys have run different aftermarket setups in the stock/replacement size, with good results.
Old Sep 12, 2006 | 09:05 PM
LeanNCut's Avatar
Exclamation
You'll need 18" or larger rims to fit Brembo/Stillen. Oh yes, and the 3K+ you mentioned.
