what is the bolt circle/pattern
Old Aug 19, 2006 | 05:30 PM
Fordwitflows's Avatar
I will be getting a 3" body lift soon and am trying to find tires and rims. I got a tire size, but not sure of rims. I want a 16" rim. I was told to go with a 10" wide rim. I am unsure of the backspacing and my bolt circle? What is my bolt circle?
Will these fit?
Backspacing: 4.5"
Bolt Circle: 5x135
Old Aug 19, 2006 | 05:42 PM
kingfish51's Avatar
The backspacing and bolt pattern you listed there are exactly what came from the factory on OE rims.
Old Aug 19, 2006 | 05:50 PM
will these:
Backspacing: 4.5"
Bolt Circle: 5x135
Fit on these:
305/70/16R
Old Aug 19, 2006 | 05:59 PM
kingfish51's Avatar
Originally Posted by Fordwitflows
will these:
Backspacing: 4.5"
Bolt Circle: 5x135
Fit on these:
305/70/16R
I looked at BF Goodrich All-Terrain T/As for an example. It states 8.0 to 9.5" rim widths for that size tire. If that is all the wider tire you are going, 10" rims might be a bit wide.
Best way to find out is the the tire makers site. They list the recommended rim widths.
Old Aug 19, 2006 | 07:52 PM
Rock Krusher's Avatar
Yup they'll fit fine. I have 305/70/17's on 17x10's and they fit just beautifully. There are quite a few people on here that have 285's on 10 inch wide rims and they fit just fine.
Old Aug 19, 2006 | 07:55 PM
Johngs's Avatar
You should be able to fit 305's on a 10 inch wide wheel without problems, Ive seen quite a few people with that setup and have no problems.
Old Aug 19, 2006 | 10:24 PM
wandell's Avatar
Yes, they will fit fine. You have the correct wheel.
