15" on 99
Old Aug 14, 2006 | 04:00 AM
stretch104's Avatar
15" on 99
will 15" wheels fit on my 99 f150?
Old Aug 14, 2006 | 07:22 AM
kingfish51's Avatar
No, won't fit over the calipers.
Old Aug 14, 2006 | 12:27 PM
wandell's Avatar
Right. You have to use 16's or bigger.
Old Aug 16, 2006 | 06:17 AM
JASON'S98S/C4X4's Avatar
Eagle Makes A 15x10 Rim That Will Fit. It Has Enough Back Spacing To Clear The Calipers. I Believe It Is The Eagle Alloy Series 118 It Comes In Crome And Aluminum
Old Aug 16, 2006 | 08:02 AM
wandell's Avatar
True. You can squeeze that 15 on 97's and 98's but the problem is fitment. That wheel only has like 2.5 inches of backspacing. This will push the tire way outside the wheelwells causing fitment problems. You will be much better off in the long run to go with 16's.
Old Aug 22, 2006 | 11:45 AM
Yes A Lift Is Required To Fit Those Eagle 15" Wheels
