Tire Pressure
The 2 different sizes are 2 different types of tire. The 325/60/r18 on the Nitto site are listed as LT tires with a max pressure of 65. Sounds like a load range D tire. I would run those at around 44-46. The 305/50r20 do not show as an LT tire. They just show as extra load with a max of 50. Sounds like a beefed up P series tire. I would run those at around 40.
Thanks kingfish51, I was thinking about 40lbs myself, and just drove to filem up a while ago....was running about 35lbs. With gas the way it is, every little bit helps!
For what it's worth, the exact tire sizes are 305/50/R20 120S
Appreciate the feedback, and not intention to hijack this thread, just did not want to mess up the forum with a duplicate question with minor differences.
CHIA
CHIA
What ever tire pressure you use, you do have to take a look and make sure you are not getting tire wear in the center or outside edges. Then adjust accordingly. One thing you do have to worry about on an under-inflated tire is heat. It can kill a tire. I had a problem with brakes rubbing at times and causing vibration and heat. After one episode like that, the tire on that corner could not be road forced balanced properly. Fortunately I was near getting a new set anyway, so it wasn't a big deal on having to replace the tries. I would not like that to happen with a new set.
