I need help...asap...
Old Jun 26, 2006 | 03:29 PM
05fordstx's Avatar
I need to know for sure one way or another if I can fit 295/70/R17 Nitto Terra Grapplers on my 2005 STX 4X4 Ext. Cab truck? I will be using the stock 17" wheel, and the truck has not been lifted or leveled. Will the tires fit, or will they rub?
Any help is greatly appreciated.
Old Jun 26, 2006 | 03:54 PM
PureCracker182's Avatar
I would suggest Torquing your torsion bars. They will definatly rub with out doing that. If you torque them, then you will probaly be pretty well off. Just my guess. I have 285/70/17's on mine and they fit with no problem after the torsion bar torque.
Brian
Old Jun 26, 2006 | 04:02 PM
hawg_man's Avatar
i do believe you are going to need to level the truck out, with a 2005 you dont have torsion bars so you have to buy a leveling kit. You might be able to run them okay with a little rubbing until you get the leveling kit if you absolutely have to have the tires put on now....Those should look great on there though!!
Old Jun 26, 2006 | 06:05 PM
wandell's Avatar
I agree. I believe they will fit completely stock. They will fit easily with a 2.5 inch leveling kit.
