Nitto's
Old Jun 19, 2006 | 03:06 PM
JForestZ34's Avatar
Nitto's
I was looking around and it helped me alittle bit but not to much. I have the stock Goodyear Wranger AT/S still on my truck but I'm looking to upgrade my tires. The size I have now is 275/65 R18. If I went with Nitto Terra Grapplers would this size fit without a problem, 285/60 R18. What is really the difference in the size of these tires. I know the numbers are alittle different but in what way does that change the tire.
James
Old Jun 19, 2006 | 03:43 PM
bama2005fx4's Avatar
google
go to googleand search "tire sizes" there will benumerous sites that allow you to put in tire info and it will give u exact width and height info
31.5 inches tall for the 285/60. 32 inches tall for the 275/65
Old Jun 19, 2006 | 03:52 PM
hawg_man's Avatar
the 285 60's are going to be a little wider but a little shorter than the stock tires.
Stock : 32.07 x 10.82
285/60: 31.46 x 11.22
the first number is the width of the tire in mm and the second number is the aspect ratio (a % of the first number to determine sidewall height of tire) i.e. 285 x .60 = 171...
Old Jun 19, 2006 | 07:24 PM
wxscpo's Avatar
James
Here's a couple sites I use to compute tire sizes
http://www.1010tires.com/TireSizeCalculator.asp
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Jun 19, 2006 | 07:36 PM
SKRWZ's Avatar
Or go here and there is a fitment guide as well http://www.bigcustomwheels.com
