18x10 & backspacing!!??!
Old May 24, 2006 | 03:08 PM
Tweeter1148's Avatar
what is the min. or max backspacing i can have on an 18x10 wheel.??>? i don't care if they stick out i like that look?? does anyone know? im getting ready to put a 3" skyjacker sus. lift and now im looking for wheels and tires...i am goin to run 33's on it..im just looking for some info on wheels!!?
thanks
Old May 24, 2006 | 03:28 PM
BalogUK's Avatar
well, first, i'd check the skyjacker lift documentation- usually they give you a range of rim backspacing that will work with their lift. the stock rims are 5.5" of backsp'g. so if you want to stay tucked, get 5.5" or more... if your wheel has less than 5.5" they will stick out accordingly
Old May 24, 2006 | 04:00 PM
wandell's Avatar
Keep in mind the OEM wheels are only 7.5 inches wide. So an 18x10 wheel with the same backspacing is gonna stick out 2.5 inches farther. I'd stay close to the stock 5.5 inches of backspacing.
