What size tire?
What size tire?
Hey all,
I own a 2003 f-150 2wd and im planning on installing a leveling kit to raise the front end. The truck is also due for some tires soon as well. Im curious whats the biggest tire i could fit without any rubbing? Ill be using the stock 16inch rims btw.
So you think 285's will clear the fenderwells? Im just worried about bumpsteer or bottoming out and causing some damage.
The tires im thinking about are bfgoodrich allterrains or michelin ltx m/s. Two completely different looking tires, i want the agressive look that the allterrains give but the ltx is cheaper and have a longer treadwear. Any suggestions from people who have experience with either of these tires would be appreciated.
Will 285's fit on a 16"x7" wheel? Most say the minimum wheel size is 7.5" but a shop here told me that 285's will fit on my wheels?
Originally Posted by hawg_man
yeah you'll be fine people do it all the time.
Originally Posted by wandell
I'd go with a 265/75-16 or a 285/75-16 since you are lifting the front.
