would this clear with 2.5 front lift
Old May 14, 2006 | 02:41 PM
torturekilla's Avatar
34x10.50x17 super swamper LTB mounted on 17x8 american racing victory teflon? they say u can run a 33 inch tire with no prob i was wondering if this would make much a diffrence by 1 inch of extra tire? or would i need to do some drastic changes to accomidate these tires? dunno wut the specs are on the rims like backspacing and wutnot.....but i would like advice b4 i order them.......anyways later and thanks for ur time..
daver
Old May 14, 2006 | 03:06 PM
4.5 backspacing is the rims specs 17x8 with 34 inch tires
Old May 14, 2006 | 10:22 PM
wandell's Avatar
If you have a 4x4, they should fit. However, I wouldn't put that tire on a daily driver.
Old May 15, 2006 | 09:17 PM
would this stuff my wheel wells to much or would this look decent on a truck....34s are kinda kewl.........
Old May 15, 2006 | 11:31 PM
Quackaddict's Avatar
Look cool yes it would.........however from personal experience and I am also with wandell.
The LTB are a bias and a very square tire they flat spot very easy (just from sitting over night) and at low speed are a VERY rough ride and dang near impossible to balance unless you do the fill them with sand type balance even then good luck. they are ok at high speeds. With a brand new truck I think they may cause you a lot of premature wear on parts .
They are good offroad and I had them on my hunting truck but for a DD I would find another tire.
Old May 16, 2006 | 08:06 AM
wandell's Avatar
If you want 34's, the 305/70-17 (34x12.50) Goodyear MTR would be a much, much better choice.
