31x10.50 and Gearing....
Old May 5, 2006 | 11:48 AM
star_f150's Avatar
I've got a 91 f150 4.4 5.0 V8 which I am going to be putting a 4" lift on with wither 31's or 32's. my question is, whill I have to re-gear with the new tires? When I did the same thing with my ranger i never re-did the gearing and it was okay... but it was only 2wd... any help?
Old May 5, 2006 | 03:00 PM
ChrisT's Avatar
Do you have any idea what gear ration you currently have? I'm not to familiar with the older F-150's but here is an example of mine... I have a 02 4x2 that came stock with 3:55LS and 275/60/17 which I think is somewhere close to a 30" tire... I replaced those with 285/70/17 which is about a 33" tire. I noticed some sluggishness but I have a 4.2 V6 also. I plan on changing my gears to a 4:10 or even 4:30 ratio. I think the only problem you will have is your speedometer will be off. To sum up, I would first find out what gear ratio you currently have and go from there. Here is a chart that helped me in deciding what gear ration would be best for me. http://www.s-series.org/htm/calc/ratiotable.htm I'm sure some of the more experienced guys will give you additional or better advice soon.
