braking shakes the truck
Old May 24, 2006 | 09:08 PM
dwsf150's Avatar
Originally Posted by defective
There's no way I'm tightening them down enough to bend a big ol' rotor.
Overtighting is not the only factor, uneven torque is the other.
Old May 26, 2006 | 08:10 PM
wattsshakkin's Avatar
Unhappy
Well I drove the truck again this weekend, and it's getting pretty bad. I noticed that I CAN feel it through the peddle, but only with light braking. The steering wheel shimmies and the whole truck shakes pretty violently. I'm just going to replace the front rotors/pads and do the e-brake pads as well. Then I have alll new brakes and shouldn't have to worry. We'll see though.
I have had my rotors replaced on my 04 f150 screw 4 times now. With every oil change i get a rotor change too. This time they also changed out the calapers. I just got my truck back today. Has anyone else had this problem.
Old May 27, 2006 | 12:54 AM
cwbpro69's Avatar
wattsshakkin:
I had that problem on my 04 FX4. Two different sets of rotors replaced under warranty, and then they finally replaced the entire front brake assembly. I do not know what exactly is involved in the replacement, but ever since it was done there has been no shimmy, no squeking, and the brakes actually seem to react when I press the pedal. You might want to look in to having this done! Hopefully you are still under warranty!
