wheel spacers on rear wheels
Old Apr 6, 2006 | 11:15 PM
dodge_slayer01's Avatar
i know wheel spacers are not good for the front wheels vut what about the rear. the reason i am asking is when i install a spindle lift the front trac will be extended 1/2" on both sides. i want the front and back wheels to be even. i know i can change the back spacing on the rear but then i can't rotate my tires. so if i get 1/2" spacers and longer studs for the rear will it be ok?
Old Apr 6, 2006 | 11:29 PM
wandell's Avatar
If you go with the spacers that bolt to your studs and have seperate studs on the spacers, you will probably be alright.
Old Apr 7, 2006 | 06:38 PM
ok thanks i hope i can find one thats only a half inch.
