265/70/r16?
The width of the tire is indicated by the first number, 265mm, which is about 10.43". (Divide by 25.4 to convert to inches.)
70 indicates the percentage of the first number for determining the sidewall height. 70% of 265mm = 185.5mm. 185.5mm / 25.4 = 7.3"
To get the height of the tire, multiply the sidewall height (7.3") by 2 and then add the diameter of the wheel. So, 7.3" * 2 = 14.6" + a 17" wheel would give you a tire height of 31.6".
Here's an online calculator: http://www.discounttire.com/dtcs/infoTireMath.dos
Hope this helps.
-Jerry
Hope this helps.
-Jerry
