Hankook Tires
Old Mar 10, 2006 | 03:15 PM
sorcerer's Avatar
Hankook Tires
My 04 F150 super cab 5.4 l 2 x 2 came with Dynapro p235 70 R17 tires. I'd like to go to a LT 245 70R17 as I'm towing a 5th wheel. I have Hellwig helper springs. Would I have to modify anything. Ford didn't offer a optional tire at the time of purchase.
Old Mar 10, 2006 | 05:48 PM
expy03's Avatar
Just keep in mind that a taller tire will result in a higher final drive ratio which you will feel when you pull your trailer. It's like putting in a different rear gear. Going from a 3.73 to a 3.55 depending on tire size. If you are pulling a max gvw trailer, I would stick to the stock size unless you are willing to also change the rear gears.
Good luck.
Old Mar 12, 2006 | 04:14 PM
svt2205's Avatar
You don't have to do a thing. A single step up in tire size like you've noted, isn't enough to worry about. That's only a 1/2 inch increase in overall diameter and a little more than 1/4 inch increase in width.
Old Mar 12, 2006 | 05:43 PM
sorcerer's Avatar
Hankook Tires
Thanx for the input guys. Much appreciated
Old Mar 12, 2006 | 06:10 PM
cyclone vampire's Avatar
get rid of the hancooks...thier 2ply's of tiolet paper...LT 245 or LT 255 or even 265 70 17 will be ok, ( I put BFG RT T/A 265 70 17 0n my 04 ) and I tow...the odd travel trailer ( no Fith wh ) and horse trailers, quads, ect..
