wheel/tire options?
Old Jan 24, 2006 | 08:54 AM
slowtruck's Avatar
Question wheel/tire options?
I have an 04 heritage reg.cab 4.6 and I have decided on a rancho 4in sus lift. Rancho says you can only fit a 33s. Im trying to decide what wheels, size tires if I can go 35s, and what would be the best back spacing? I will be getting some 4:10s put in also. I would apreciate any opinions. Thank you.
Old Jan 24, 2006 | 10:50 AM
05supercrew's Avatar
Back spacing would be 5.5 or close to that. Tire size is up to you, look around do you want 17s 0r 18s? If you went with a big 18 you may want 4.30 gears instead.
Old Jan 24, 2006 | 11:40 AM
slowtruck's Avatar
I want to go 17s. also how bad would gas be with 430s?
Old Jan 24, 2006 | 03:56 PM
wandell's Avatar
He has a heritage edition (same as the 97-03's). You want a wheel with 4 1/2 inches of backspacing, like the OEM wheels. Yes, you can fit 35's with the Rancho lift. Personally, I'd suggest going with the 5 inch RCD or 6 inch Fabtech lifts with 35's and 4.56 gears since you have a 4.6 engine.
