new wheels and tires on my 05
Well it's time for some wheels and tires for my 05 lariat. Can anyone recommend some good web sites where you can get a good look at some different rims? I'm going to put a levelling kit on as I want to put 33" tires on it. I have seen alot of talk about backspacing?? what do I need to look for to get a proper fit? I don't like when the tires stick out too far.
any and all comments would be welcome.
Originally Posted by wandell
I agree. Try to stay with a wheel with 5 1/2 inches of backspacing with a 285mm to 325 mm wide tire.
Originally Posted by MarkM3
Could we perhaps list some of the wheels avaliable with proper fittment? I'm in the same boat, in that I want new wheels but it seems as if everything avaliable is the wrong backspacing. Moto Metal's for example, are extremely popular but stick out 1.5" over stock.
SC 05FX4
The way your tires are set up really looks awesome! It is what im looking for. They seem to fit just perfect. I see in your pics you have the rancho shocks. Do they take the place of a levelling kit? How is the ride compared to the factory set up? Do you notice much of a difference?
Originally Posted by knoxboys
SC 05FX4
Originally Posted by SC_05FX4
If you don't want your setup to "stick out" past the wheel well, I would go with a wheel 8 to 9 inches wide with 5.5" backspacing, and a 285 diameter tire.
Originally Posted by ackackadak
I have 8.5" Weld Evo wheels with 5.5" backspace. I think a 9" wheel might put the tire outside the fender lip; I suppose it depends on how big you go on the tire. I have 315/70/17 BFG tires mounted that absolutely do not stick out or rub. I'd consider the 315 tire if you get the rest right. Check out my gallery.
I did not like the way the 315 tires raised the final drive ratio. The truck felt too sluggish for my taste. I needed more performance. The 4.56 gears are just about perfect with this tire. I can turn the tires over, I have decent off the line performance and I love driving my truck again (even more than before).
Originally Posted by devilsslide
Do you think that the 4.10 's are not enough?....
Thanks for your input!
They weren't enough for me. Keep in mind, I drive in traffic to and from work everyday. I'm running stoplight to stoplight sometimes; almost no highway driving whatsoever... that said, the perfromance can't be beat. I am a happy camper.
What are you getting for mileage with that low of gears ? I am planning on doing the same setup that you have (Looks Great!) but don't know much about gearing. My truck has the 3:73's and most of my driving is highway, am I going to be okay with stock gears or do I need to budget for different ones later ?
