Right tire size
Right tire size
I have a 2001 super crew and I just bought a set of 18 x 8 chrome rims.
What size tires is going to fit the rim and be as close to the oem size as possible.
Stock size is 255/70R16
I am leaning towards 265/60R18
Any help would be great!
IF you are right about stock tire then you need a 255-50/18. I thought stock tire size was 265-70/16. If that is the case you need around 295-55/18. I could be wrong. Over all tire height should be around 30". I run the tire size recommended in door panel of my truck, 275-60/17. That tire is 30" even. I may be wrong look on your door panel drivers side for stock size on your truck. Then use this Calc. to figure the new size tire. Tire Calc.
Scotty
Scotty
I have a 4x2 and the stock size is 255/70R16. The new rims are 8.5 wide not 8. 255/60R18 is almost the exact size. But the stock rims are 7 wide and the new ones are 8.5. Will the same width tire (255) work on the differnet width rims.
Hope this helps,
Scotty
P.S. Post some pics when done.
